Am I missing something? How do you get this to work?
geposted Sat 26 Mar 05 @ 3:36 am
You first have to create a loop with the current butons or shortcuts.
Make sure the plugin is activated.
Then slect the option you want (bigger loop / go backwards then in the loop again / ...)
geposted Sat 26 Mar 05 @ 9:31 am
Hi djcel;
Very good work again.
This plugin is interesting.
I noticed a problem.
When you select "length + x beats" (n°4) the loop is bigger but it stopped just before the next CBG according to the number of beats. If you create your loop before between two beats and select for example lenght + 4 beats it stops just close to the last CBG of the loop and go back to the entry point. So it's not synchronized in beats.
geposted Sat 26 Mar 05 @ 9:35 am
Well first it's useless to activate the plugin, it works without
This plugin enables you to do the same thing as with the black disks on skins. Move the entry in a loop in beats was already created but not the length. So is the goal of my plugin
Then i don't undertstand why Clax because i use bpm and for me it works. It's not on beats but in beats ;-) Maybe the bpm of your song is not good or cbg... I will have a look.
I think a will put 2 sliders instead of one. One for each: start (i called In but finally i do't like this word) and the other for length
geposted Sat 26 Mar 05 @ 2:24 pm
Hi cel;
Maybe I'm wrong with my explanations because of my english. I'll continue in french on MSN.
PS: My CBG and BPm were correct during my tests.
In fact it goes to the Xst beat after but not to X bpm.
geposted Sun 27 Mar 05 @ 8:28 pm
That's it you add or remove x beats but not create a loop of x beats
geposted Sun 27 Mar 05 @ 9:37 pm
thank you for the explaination!
geposted Mon 28 Mar 05 @ 4:08 am
I found the bug Claxx, update (v1.2) soon
geposted Mon 04 Apr 05 @ 12:37 am
I knew it was a bug ...
Great work. It's sometime very hard to identify a bug and you did it. Thanks.
geposted Mon 04 Apr 05 @ 10:25 am
thanks verey much
geposted Tue 19 Apr 05 @ 3:28 pm
