Forum: VirtualDJ Skins
Topic: Installing skins
I am having troubles installing the skins which i have downloaded from this site. I understand what i need to do to install a skin that is in zip format, but do not understand what i need to do with files which are of type "application/octet-stream".
Can anyone please tell me how to install this type of file as a skin?
Your help is appreciated,
Cheers
geposted Sun 27 Mar 05 @ 3:45 am
I've also noticed that some downloaded skins come without the file name extension '.zip'.
Try renaming the file and add '.zip' at the end.
it's a browser related problem. If you are not using Internet Explorer (Mozilla for example), it somehow fails to add .zip extension.
Thank you, I think that will help me out here.
