Hello ppl,
I got my Maya 44USB today and wanted to try some timecode controll on my cd player. So I installed the sound card, installed the ASIO drivers for it and plugged it in. I read tutorial on the internet and tried to make it work. Now the music plays, and when I push the play button on my CD player the music starts, but that's actually the only thing that I can controll with my cd player. When I want to go back to the beginning with my cue button, it won't work. When I press cue, it just pauses my track, untill I press cue again. Also, when I pause and I want to search for my cue point by going back and forth with my platter, the music just continues playing again. Here are some screenshots of my settings.
http://img2.imageshack.us/img2/43/pro3.jpg
http://img261.imageshack.us/img261/5452/pro2o.jpg
http://img20.imageshack.us/img20/1521/pro1i.jpg
I use the VirtualDJ5 controll cd's. At first, I had a 100% signal quality, but now it says 0%. I hope that someone can solve my issues. I have the Maya USB 2.85 ASIO driver installed, but I tried it as well with some other versions and they did not work.
geposted Mon 08 Jun 09 @ 8:30 am
You are using relative timecode mode; change it back to the default - Smart.
https://virtualdj.com/wiki/TimeCode.html
geposted Mon 08 Jun 09 @ 9:41 am
I think I have tried that, but didn't work. Will try it again this evening.
geposted Mon 08 Jun 09 @ 9:46 am
Relative mode will definately prevent you using cue as you intend... it needs to be Smart or Absolute.
geposted Mon 08 Jun 09 @ 9:49 am
I've got it on Absolete now and it still wont work. Only if I press it like 4 or 5 times it will go back. When I just press it, my song just pauses.
EDIT : When I press my cue button for 2 seconds, it does work :/ Can some1 tell me how I can make this instant ?
geposted Mon 08 Jun 09 @ 10:15 am
