Forum: Old versions
Topic: Creating Back Beat function in Denon HC 4500
I'm attempting to re-create the JPBoggis Back Beat function within the new mapper but I'm having trouble since there seems to be no verb connected to this functionality. In JP Boggis's Mapper it was Back Beat <<1 or <<4. Can anyone help?
geposted Tue 09 Jun 09 @ 7:14 am
what do you actually mean by "back beat" and maybe I could help?
I think it means basically moving one beat or 4 beats back in the song (or moving the loop) by pushing the forward or reverse buttons.
If you want a shortcut to go back 4 beats, use......
goto -4
forward 4 beats =
goto +4
you can define however many beats you like
Hope this helps
PJay
I believe you solved my problem. I will test tonight. I'm just looking to repeat 1 beat by going back -1 or -4. Kind of like a stutter effect
Your welcome
I have the same actions mapped to 1 key
press it on its own and it goes back 1 beat
press it while pressing a shift key and it goes back 4 beats
PJay
Thank you so much! This answered the question I was about to ask too! Great function. Thanks for the info!!
