On the last couple of gigs I've done I've Had a problem with the pitch of one song affecting the pitch on the other player.
Having to watch helplessly as the pitch resets to a totally unwanted value (syncronised) and not having any ability manually override this.
Looking through previous postings thr DeV, team said the issue MAY? be addressed....
also previous versions did not have this problem....Can we have Access to these earlier versions, as at this point I dont use TCV.
I Hope this Issue IS going to be addressed in 2.07 whenever that is released.
geposted Tue 29 Mar 05 @ 1:15 pm
(nt = no text)
geposted Sat 02 Apr 05 @ 4:22 pm
disable pitch reset in fame settings...
geposted Sat 02 Apr 05 @ 5:33 pm
Thanks I'll Try That,i'm sure that will do the trick.
geposted Sat 02 Apr 05 @ 11:03 pm
pitch reset didn't work ...............BUT.........................setting AUTO BPM to DISABLED seems to work for me.
Thanks heaps norway for your help.
Something I love here is the trully international nature of our virtual dj community.
geposted Sun 03 Apr 05 @ 1:10 pm
Ain't it cooool!
MS
MS
geposted Sun 03 Apr 05 @ 4:09 pm
sorry.. disable AUTO BPM of course ;) thats it
geposted Sun 03 Apr 05 @ 8:30 pm
