Forum: Old versions
Topic: Mapper command to impact both decks simultaneously?
In the mapper, you can designate which deck you want a command to apply to, "deck 1 etc."
Is there way to tell the command to influence both decks at once? I'm trying to get key_lock to trigger on both decks with one button.
UPDATE: I found the solution... https://virtualdj.com/wiki/VDJscript.html
Use the & sign to build compound commands: deck 1 command & deck 2 command
cheers
geposted Sun 14 Jun 09 @ 9:56 pm
