hello -
there are several songs that really are no different from the others except in the way virtual dj loads them. what virtual dj will do is load maybe 1 second and a half of the song on the graph above and that's it. no matter how many times i analyze it in advance or how many times i load/play it, virtual dj never seems to "pre-load" the entire song. has anyone seen anything like this? i'm using demo 2.05
thanks
-marc
thanks
-marc
geposted Thu 31 Mar 05 @ 7:02 am
check your max load time in the fame settings tab in the config...
geposted Thu 31 Mar 05 @ 8:58 am
Correct the max load setting should be higher than the length of the song
Andre
Andre
geposted Thu 31 Mar 05 @ 4:41 pm
By the way this is meant to limit the amount of memory eaten up by the software as it runs. Loading an entire song in memory takes roughly 10 MB per minute so if you load up a 15 minute song it'll take 150 MB off your memory. You should not set the max load to too big an amount (10 or 15 minutes seems fine)
geposted Thu 31 Mar 05 @ 4:57 pm
