Hi. I have VDJ 2.06 and I am trying to configure 2 sound cards. The first one is an nVidia onboard soundcard and the second one is a Creative usb soundcard. I'd like to have the music come out of the speakers, which are attached to the onboard soundcard, and I want to preview the next song via my headphones. I feel I have tried just about every configuration, but I only get the current desk playing on either the onboard or headphones and absolutely no preview. It was so simple on vdj 1.xx. A little guidance here will be greatly appreciated. Thanx.
geposted Fri 01 Apr 05 @ 1:52 am
Theres only 1 output enabled on trial versions. If you do have a full version go to settings, sound card, scroll down and select advanced configuration(3rd from bottom) and set up the sound cards whichever way you want them.. oh and also register your version:))
geposted Fri 01 Apr 05 @ 2:13 am
That feature is disabled on the trial version.
You however are using a cracked version (2.06) with an invalid serial number.
The feature you seek is very easy to manipulate in the legal full version.
Uninstall your cracked version and purchase the full version.
Then all technical help will be joyfully given.
Please don't come here looking for support on a stolen version of this software.
geposted Fri 01 Apr 05 @ 2:38 am
