I am using the trial version of VDJ and testing the karaoke function. I seem to be unable to select it. I don't get an 'Activate' button like the other plugins in the list. I get the video window for the lyrics. Is this because it's the trial version or something else?
geposted Thu 25 Jun 09 @ 1:30 pm
geposted Fri 26 Jun 09 @ 4:56 am
I received this message when I when to the link: 'Sorry, you don't have the necessary accreditations to view this page.'. I apologize up front if I don't have the approval to ask questions here since I haven't purchased the software yet. I am just trying to test the karaoke function to make sure it works for the environment I will be using it in. I don't mean any disrespect. Thank you for your time.
geposted Fri 26 Jun 09 @ 10:28 am
gary have you the latest versions of c++ and directx installed if not you need to, all plugins require these two elements for them to work, now what you can and can't use in the trial version i'm sorry just can't remember, but i would imagine you will have a limited use of the karaoke player, hope that helps...
geposted Sat 27 Jun 09 @ 10:32 am
Sorry, didn't realise that topic was levelled up, apologies.
As above, make sure you have the latest DirectX installed:
http://www.microsoft.com/downloads/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
geposted Sat 27 Jun 09 @ 11:57 am
