Forum: Asian Forum
Topic: hello to all (Philippines Thread) - Page: 11
@sir diced
ganun pa rin ang nangyayari. I'd even tried to select every choices in the drop down menu of Asio.
nag-lalag pa rin yung sound wave at yung music.
im not sure kung pwede talaga sya sa component under auxiliary menu
geposted Tue 22 Nov 11 @ 10:40 pm
Bro may land line kaba?mukhang may nalimutan ka sa configuration using your I/O board.Try to read it carefully again if you missed something pagdating sa I/O board.
geposted Tue 22 Nov 11 @ 10:43 pm
yes sir i have kaso hindi ko matatry kasi nasa office ako.
after ko mainstall yung djio wala na akong ginawang set up or change in configuration.
the only menu or set up lang na nakita ko is yung sa menu ng sound > asio
geposted Tue 22 Nov 11 @ 10:59 pm
Bro,
LE kasi yung gamit mo kaya yun lng ang menu na ioffer ng software mo.At di din ako familiar sa Numark Mixtrack.
So pag nag start kang ikabit ang Audio I/O that is the time na nag kaka issue ka sa software at audio application mo.
Bro matanong ko lng kung ano ano ang software na included sa Mixtrack mo?
geposted Tue 22 Nov 11 @ 11:20 pm
If Im not miskaten after ng installation dj
I/O you need to change the setting sa Sound card under Sound set up sa Config.tama ba ako?
geposted Tue 22 Nov 11 @ 11:25 pm
oo nga bro LE yun. Virtual DJ LE ver. 6
ano kaya pwede ko gawin sir para gumana yun?baka pag nilagay ko sa malaking speaker na pang club hindi lalo gumana.
FYI: di ko pa rin natatry yung headphone so yung output 1 pa lang nasasaksakan ko.
Thanks bro
geposted Tue 22 Nov 11 @ 11:29 pm
I already changed it na bro. yung mga nakaselect dun is NONE, below that is HEADPHONE, and below that is ASIO.
pero sa last selection ang gamit ko is SIMPLE kasi yung nga, ayaw sa component
geposted Tue 22 Nov 11 @ 11:30 pm
My built in sound card ba ang Mixtrack?
geposted Tue 22 Nov 11 @ 11:40 pm
Bro,
Im reading the manual of dj I/O,matanong ko lng kung saan nakaka bit yung RCA output ng dj I/O mo?
geposted Tue 22 Nov 11 @ 11:43 pm
base on what I understand,if you use dj I/O Audio interface, your main audio output will be at the rear of the dj I/O.
Then try mo din click yung drop down window ng Asio and check kung my ibng choices.
geposted Tue 22 Nov 11 @ 11:49 pm
ganito ba setting mo?
Inputs : none
Outputs : headphones
Card : ASIO
DRIVER : Numark USB
Channels 1/2 main 3/4 headphones.
make you're running only one asio driver
try mo din sa ibang usb port, baka kasi defect yung port na yun.
geposted Wed 23 Nov 11 @ 12:33 am
bro, walang built in sound card yung mixtrack that's why i also bought djio.
nasa rear nga yung output ng rca. i haven't tried yet na ilipat ng ibang usb port yung djio. though naka-on naman yung power ng djio kaya isa lang yung pinaglagyan ko.i will try it next time na ilipat sa ibang port.
regarding sa setting , ganyan yung setting ng config ko. yung drop down naman ng ASIO napili ko na lahat ng choice from lower to higher.
hindi ko alam kung ano problema. gusto ko itry sa ibang amp or speakers baka nasa component lang ang problema pero wala na ko kasi ibang
masubukan.
geposted Wed 23 Nov 11 @ 1:37 am
saan ba location mo?
geposted Wed 23 Nov 11 @ 5:39 am
djranesPRO InfinityMember since 2007
geposted Wed 23 Nov 11 @ 9:21 am
@dustineph - bro pasay ako.
@djranes - bro thanks! hindi ko pa natry yung config - > performance -> latency menu kasi sa config ko 2 menu lang yung nandun. yung una yung set up at yung pangalawa yung offer ng 20 days trial ng vdj pro. kailangan ko pa bang mag-upgrade to pro?
Thanks!
geposted Wed 23 Nov 11 @ 7:08 pm
Saan sa Pasay? ano ok na ba configuration mo?
geposted Thu 24 Nov 11 @ 1:11 am
Libertad ako bro near taft ave.
hindi pa bro mamaya ko pa lang aayusin ulit.busy sa office kasi.
Pasay ka rin ba?
geposted Thu 24 Nov 11 @ 4:03 am
Wazzup mga sir. Napadaan lang. Matanong ko lang kung may alam kayong mura sa may raon hehe I'm planning to buy speakers and amplifier hehe any suggestions would help ;)
geposted Thu 24 Nov 11 @ 3:03 pm
@djpaulskie
Dahil nga LE ang software kaya di mo mapasok ang config menu. Ika nga LE = limited edition.
Pwede mong subukan ang PRO na trial for 20 days to prove na sa config settings ka ngkulang.
Wag kang matakot kung mg-expire ang 20 days trial na yan at kusang babalik sa yan LE.
Ang isa ring dahilan ay baka hindi mo nakuha ang tamang set-up sa ASIO driver ng soundcard mo, in this case DJIO.
Ika nga too less latency setting ay mgkaproblema sa audio glitches or cracks dahil di na makayanan ng system mo. Too high latency set-up naman ay mgkarooon ng delays, e.g erratic waveform display and or unresponsive performance sa software mo or no audio at all in worse cases.
Tandaan, sa bawat settings na iyong babaguhin ay kailangnang i-restart mo ang yung software para umepekto.
geposted Thu 24 Nov 11 @ 4:06 pm
Paulskie,
Nope SanPedro Laguna ako.
Javeconsul,
yup marami sa Raon kaso ingat lng kasi maraming pekeng mabibili sa raon.
Djranes,
so more on software configuration issue ang na encounter ni dj paulskie.
geposted Thu 24 Nov 11 @ 10:54 pm
19%
