pogi!
bumili ka ng RMX maayos na controller ito. may computer ka naman di ba? libre pa ang VDJ kaya lang hindi pa Pro.
bosabose
bosabose
geposted Fri 08 Jan 10 @ 5:10 pm
hi pipz...
i need your help kung paano ausin ang config ng vdj... the program was spinning backwards once i hit the needle on the time coded vinyl.. pls help. salamat!
geposted Mon 11 Jan 10 @ 11:51 am
Dre iwasan magdoble post kasi malilito yung mga sasagot.
Hope nasorted out mo na problema mo.
Welcome to VDJ forum.
geposted Tue 12 Jan 10 @ 7:31 am
thanks sa pag welcome sakin.... anyway... nakareceive na rin aq ng magandang advise and maganda rin ang result sa equiptment qo... salamat
geposted Tue 12 Jan 10 @ 8:44 am
hello,meron ba nagamit ng xsession pro with vdj paturo naman hirap set ang mappings sa xsession pro,
geposted Sun 24 Jan 10 @ 5:06 am
Mga Sir,
newbie lang ako sa virtual dj pero gusto ko talaga matuto gamitin toh kaso ang tanong ko.. pano ko mapapakingan yung music sa deck two para maipasok ng maganda habang nagpplay ang deck one? kasi usually tinitimpla mo na dapat yung next song... thanks
geposted Mon 25 Jan 10 @ 9:08 am
Nicepher wrote :
Mga Sir,
To prelisten, kailangan mo ng soundcard na may 2 output or 2 soundcards para sa master and headphone.
Kung ala, pwede mo i-set ng split para yung left maging master mo and right maging headphone mo PERO mono lang ang kalalabasan nito.
geposted Thu 28 Jan 10 @ 8:26 am
Good day sa mga kababayan ko dyan sa pinas!
@ bosabose, kmusta na po ang performance settings ng RMX nyo?
geposted Thu 04 Feb 10 @ 5:27 pm
medyo ok na rin I'll just have to live with few drop-outs. t y sa nga tip mo
geposted Sat 06 Feb 10 @ 4:24 pm
ariel,
hindi ba nag-b-blink yung sync button ng rmx mo kapag may pinapatugtog ka?
geposted Sat 06 Feb 10 @ 4:32 pm
if you still have few drop-out, try mo idisconnect yung internet connection mo (if you are connected to the internet) and also disable your antivirus software before you start using VDJ & RMX
with regards to Sync button, Nagbi-blink po sya.... sumasabay sya sa beat ng tugtog.
geposted Sat 06 Feb 10 @ 7:48 pm
disconecting the internet connection nullifies the added feature of netsearch in vdjpro. i've been using this feature to get songs from the net!
geposted Sun 07 Feb 10 @ 9:37 am
Bosing, try ka mag-tweak sa system mo.
Common problem ng audio dropout ay system latency.
Yung mga system hungry na mga processes na hindi mo kailangang patakbuhin ang subukan mong i-stop.
Example:
Theme
Search indexing
Security
UAC
If possible patakbohin mo ang windows mo in best performance.
As much as possible try to run at a minimal process if can.
Naway yan ay makakatulong.
Example:
Theme
Search indexing
Security
UAC
geposted Tue 09 Feb 10 @ 7:36 am
na-itweak ko na itong computer ko base dito sa nga suggestions sa forum-pero paminsan minsan may mga drop-out parin. Tinangal ko na pati anti-virus pero ganun parin. kanina ginamit ko rung rmx ang daming drop-outs! hindi kaya malamig palang ang system? kasi nasa basement namin naka set-up itong system ko.
geposted Thu 11 Feb 10 @ 8:02 pm
Bosing, di kaya nagka-experience ka ng overload ng USB port mo?
Try mo kaya run ang RMX na ng-iisa lang, alang ibang nakakabit sa mga USB port.
Maranasan ko rin audio dropout sa mga CJD400 ko at narectify ko by installing ground loop isolators sa RCA pati na rin sa power supply strip ko.
Sana makakatulong yan...
geposted Fri 12 Feb 10 @ 7:32 am
Thanks sa tulong mo DJRANES!
geposted Sat 13 Feb 10 @ 9:56 am
muzta sa inyong lahat...bumili pala ako ng vestax vci-100,hindi ko sya maset ang mappings nya,paturo naman paano set ang mappings ng vestax vci100 sa vdj.meron ba sa inyo nagamit ng vci 100?add nyo na lang ako sa....
edit by spinna
sorry no email or contact info is permitted from no license user. Thanks for the understanding.
edit by spinna
geposted Sun 21 Feb 10 @ 5:36 am
hello po! testing out the software as of the moment
geposted Sat 20 Mar 10 @ 8:26 pm
You have 20 days to try it out, for sure you will like it!
Hope you will come back and buy the software legally from here.
See you soon...
See you soon...
geposted Tue 23 Mar 10 @ 2:06 am
kmusta po sa mga pinoy dj's dyan. ask ko lang po baka meron kayo copy ng mp3 music na:
1. Steve Perry - Foolish Heart (remix)
2. Claire Marlo - Till They Take My Heart Away (remix)
3. Kalapana - The Hurt (dance remix)
sumikat po ang mga dance music na 'to noong early 90s. kung may alam po kayo na music store sa internet na pwede maka purchase nito paki PM lang po sakin ang website. maraming salamat!
DjAriel
DjAriel
geposted Fri 02 Apr 10 @ 6:15 pm
