Good news!
I received an e-mail confirmation that my SP1 already arrived. 'Will pick it up this afternoon.
I will let you know how it works both with Serato DJ and VDJ.
There's already a mapping available for this unit both for Mac and PC:
http://www.virtualdj.com/addons/16395/Pioneer_DDJ-SP1.html
geposted Tue 07 Jan 14 @ 1:34 pm
The little badboy has arrived... Really cool to play with... Kailangan nga lang sanayin dahil halos lahat ng controls ay may ibang function sa shift.
Kahit anong controller na may built-in soundcard ay pweding maging DDJ-SX with this unit added. Pwede na munang i-keep ang NS6 for the time being.
geposted Thu 09 Jan 14 @ 12:45 am
Yeeeey!!!
We just reached the 1000th mark for the number of posts!
We are the most visited area ASIAN here at VDJ Forum!
geposted Mon 13 Jan 14 @ 1:18 pm
Di kaya sadya lng madaldal ang mga pinoy?
geposted Tue 14 Jan 14 @ 12:41 am
wala lng sigurong magawa..
question lng mga Idol..
geposted Tue 14 Jan 14 @ 6:46 am
Nag download ako ng skins pero di ko ma
install kasi unknown developer daw..any suggestion.
geposted Tue 14 Jan 14 @ 6:49 am
If this is on a Mac (most likely default security)...
Just right-click on the zipfile then click open.
You can disable this option somewhere in the settings.
I hope this is the case : )
geposted Tue 14 Jan 14 @ 8:52 am
done..thnks..
geposted Wed 15 Jan 14 @ 3:03 am
Mga kakabayan - will upgrade to Macbook Pro this year. Any suggestion on specs na may matitira pa sa savings ko...heheh! 15" daw pag video application.
geposted Sat 18 Jan 14 @ 7:15 am
Hello Sir,
If you will use video in DJing, 15" is the way to go. If music only, 13" is more than enough.
I just bought Mid 2012 13" Macbook Pro i7 2.9Ghz 8GB Ram 750GB HDD, it runs VDJ & Serato without issues.
I would say, Mac is better than PC in my experience particularly if I use Serato. 938MYDJ will agree with me :)
Some DJs says: "If you go on Mac, you will never look back". :)
If medyo kapos sa budget, pwede na ang refurbished unit if you buy directly to apple.com you won't notice
any difference with brand new bcoz they will replace anything with cosmetic issues as well as any defective parts found inside.
In short, para din syang brand new the only difference is you will no longer receive it in original box.
Good Luck on your new purchase ;)
geposted Sun 19 Jan 14 @ 12:53 am
Mac 15\" are the mostly used size for DJ-ing.
But technically speaking, 13\" with the same specs will do the job as well... including video-mixing.
Kung balak mong gamitin ang bibilhin mong Mac strictly (or mostly) for DJ-ing, 15\" na yung kunin mo.
Mukhang malaking tao ka rin sa picture. Baka hindi maging proportion ang trese sa yo, LOL!
Also, yung non-retina display (with CD drive) binabaan yata yung presyo kesa dati.
Keep us posted with your purchase.
geposted Sun 19 Jan 14 @ 2:54 pm
arielfm22 wrote :
Hello Sir,
Hello Sir,
Im also using MAC Pro and I bought it last year, same spec ng kay Ariel,so far Im running VDJ Pro,Traktor Pro and Maschine (NI) without any issue..
geposted Mon 20 Jan 14 @ 3:16 pm
arielfm22 wrote :
Hello Sir,
If you will use video in DJing, 15\\\" is the way to go. If music only, 13\\\" is more than enough.
I just bought Mid 2012 13\\\" Macbook Pro i7 2.9Ghz 8GB Ram 750GB HDD, it runs VDJ & Serato without issues.
Some DJs says: \\\"If you go on Mac, you will never look back\\\". :)
If medyo kapos sa budget, pwede na ang refurbished unit if you buy directly to apple.com you won\\\'t notice
PhiDJ wrote :
Mga kakabayan - will upgrade to Macbook Pro this year. Any suggestion on specs na may matitira pa sa savings ko...heheh! 15\\\" daw pag video application.
Hello Sir,
geposted Mon 20 Jan 14 @ 3:32 pm
Thanks sa mga advise nyo guys. Will keep you posted.
938MYDJ - like the key sticker on ur Mac.. :)
geposted Mon 20 Jan 14 @ 9:42 pm
There you go... It's a good idea na madaling gayahin, lol!
I used Mixed-In-Key (damay na pati Serato at Traktor key-tags). Unlike Virtual DJ, it's not biased on minor key detection. It's an extra time to spend kapag nag-aayos ng library, pero kapag dati mo ng ginagawa masasanay ka na rin lalo na't sulit naman siya. Di pa nga ako nakakapag-upgrade. May bagong labas na version 6.
Anyway, back to moving to Mac topic...
Para sa akin, Laptop (computer) ang pinaka-importanteng gamit sa digital mixing... pangalawa lang ang software at pangatlo ang controller.
I am happy to see more and more visitors here moving to Mac. It's a smart investment and will eliminate or at least minimize your worries.
Na-mi-miss ko tuloy si Pareng Cesar Castillo ... Nasan ka na pare ko?
geposted Mon 20 Jan 14 @ 10:55 pm
Oonga,nasan na kaya si Cesar Castillo? nananawagan po kami kung sino po ang nakakakilala kay Cesar or nakakita sa kanya,ipag bigay alam lng po dito..lol
di kaya nag shift na ng software..he!he!
geposted Tue 21 Jan 14 @ 8:09 am
Hi , I im a new member of virtual dj, hope i can learn more about this
I love this much
I love this much
geposted Tue 21 Jan 14 @ 4:40 pm
Play around with the free home edition. Then try the PRO Trial Version.
If you will like it then aim to buy the Full Pro Version to enjoy all the features and of course the free unlimited version upgrade.
Enjoy!
Enjoy!
geposted Tue 21 Jan 14 @ 5:30 pm
Si Cesar ba ung taga Saudi?
geposted Tue 21 Jan 14 @ 8:55 pm
Tanda ko kung hindi Dubai, baka Abu-Dhabi...
Let me dig from our PM exchange and let you know.
Medyo hindi maganda ang experience niya sa Mac kaya ko siya na-alala.
Like any other products, minsan may sumabsablay din na mangilan-ngilan sa mga batch na nilalabas nila. I think this was the case na nangyari sa kanya.
geposted Tue 21 Jan 14 @ 9:51 pm
