Hi does anyone know how to make the equalizer plugins effects installed into virtualdj?I downloaded it and do not know into what folder it should go..
geposted Sun 03 Apr 05 @ 4:21 pm
The plugin should go into your effects folder in the VDJ directory. Put it there, restart VDJ and then activate it in the effects section of your VDJ skin. Should work. Try it and let us know if it does.
MS
MS
geposted Sun 03 Apr 05 @ 4:34 pm
Yes thanks it works now.The problem was that when i downloaded it prviously it did not come in .dll format it came in some other format.So I tried again and it works now.
geposted Mon 04 Apr 05 @ 12:49 am
Maybe you use another explorere than Internet Explorer.
Somtimes with other ones (Firefox and others) you have to write the extension manually.
Happy to see you your problem solved.
geposted Mon 04 Apr 05 @ 10:30 am
Yes that is 100% tru.I really used firefox to download it.
geposted Wed 06 Apr 05 @ 5:28 pm
