First I wanna say I'm sorry for posting this question on this effects page, cause I don't where should I post this question.
My question is, is there any tutorial how to create a sample for VDJ? I see there's tutorial for creating skin or effects, but not for samples.
or if there's somebody who's kind enough to give us tutorial for how to create the samples (*.vdj files), I'll be thankfull.
Thank you very much, and I'm sorry for posting this threat in this section.
King Gober
King Gober
geposted Sun 03 Apr 05 @ 6:06 pm
I believe that it's written in the user guide...
Well, ou select the default desk (use TAB above capslock on your keyboard to change) on the deck you want and then:
* for a loop: press the button on the skin then press the button loop
* for a jingle: press jingle to record and press again to stop
after that you can save it with the menu of the sampler
geposted Sun 03 Apr 05 @ 6:17 pm
Thank you very much for your help djcel :)
geposted Sun 03 Apr 05 @ 9:48 pm
