I would like to configure my Karaoke Songs for Pitch and Key and have the prescribed settings automatically come up on each subsequent playing of the various songs. Is there a technique to do this? Thanks
geposted Sun 05 Jul 09 @ 6:31 pm
Not built in to my knowledge. Could be done as a plugin theoretically.
geposted Mon 06 Jul 09 @ 8:09 pm
Found a Plugin for Winamp that does this.
Can it be brought into VDJ?
It is called Pacemaker.
geposted Tue 07 Jul 09 @ 9:19 pm
Winamp plugins aren't compatible with VDJ. It would have to be rewritten from scratch. It's not particularly difficult to do though.
geposted Tue 07 Jul 09 @ 9:26 pm
Ok i have virtual dj 5.2 but i had <sc key="E" action="effect_slot_select" value="0" /> and
<sc key="R" action="effect_slot_select" value="0" />... they both was working at one point but i mistakenly switched it to effect multi select and now i changed it back but it wont do the pop up screen menu so i can lock that plugin i choose no more when i press the button it does nothing what happened?
geposted Mon 13 Jul 09 @ 3:07 pm
