hi boys,
i have some questions about this hardware :)
Can i use the Pad (in virtual dj) like a mouse and also to modular the effects?
Near the headphones jack there is a button that can switch to "Bank A" and "Bank B", what is it?
Can i use with this console the SPLIT for listen the tracks in the headphones? for exemple: in [L] the deck A and in [R] the deck B
Can i listen the Master in headphones?
In "Pedal Exp and Foot" what kind of hardware can i connect?
Thank you so much!!! :D
Faffo
Faffo
geposted Tue 07 Jul 09 @ 3:52 pm
Faffo.D wrote :
hi boys,
1>Can i use the Pad (in virtual dj) like a mouse and also to modular the effects?
2>Near the headphones jack there is a button that can switch to "Bank A" and "Bank B", what is it?
3>Can i use with this console the SPLIT for listen the tracks in the headphones? for exemple: in [L] the deck A and in [R] the deck B
4>Can i listen the Master in headphones?
5>In "Pedal Exp and Foot" what kind of hardware can i connect?
Faffo
Faffo
1> yes you can us pad just like a mouse and also to modular the effects so yes.
2> sorry have not found what this is for .
3> yes to this one you Can use with this console the SPLIT for listen the tracks in the headphones? for exemple: in [L] the deck
A and in [R] the deck B.
4> why this when you just ask that like in question 3.no
5> i have not used this yet .
you should have a look at youtube virtual dj with xponent or have a look here https://virtualdj.com/wiki/Video_Tutorials.html
geposted Tue 07 Jul 09 @ 6:08 pm
Thank you very much for your support :)
geposted Tue 07 Jul 09 @ 6:31 pm
