Hi I would really like to see virtualdj play tru mp3 like media players so that I would not have too close of virtualdj and open up other media players to let my lists of mp3s run tru.I wanna be able to open up a folder add my mp3 or music files and let virtualdj play all of them without I touching it or I having to load a track continously..................(And I am not reffering to the automatic mix feature.)
geposted Mon 04 Apr 05 @ 5:52 pm
the feature is kinda there...
press CTRL+A to select all the files in the folder you wanna play
Drag all songs to Playlist window
Go to FAME settings and choose :
Auto BPM : DISABLED
Force Fade : ENABLED
Fade lenght : NONE
This will play all the songs in row, NO automixing, NO crossover, NO bpm adustment
Just like any media player ;)
Auto BPM : DISABLED
Fade lenght : NONE
geposted Tue 05 Apr 05 @ 3:58 am
Thanks a lot bro I really wanted to use that feature I am gonna try it right away.
geposted Tue 05 Apr 05 @ 2:46 pm
Sorry but I tried everything yu said but it did not work.And new suggestions
geposted Wed 06 Apr 05 @ 12:55 am
NONE doesn't work well in vdj v2.06 and that's the reason why
geposted Wed 06 Apr 05 @ 1:02 am
It's a known bug i think, for some reason it plays only the first 1-2 tracks and then stop.
Try to set the Fade length to lowest value 1 sec, instead of none
and it might work, but with some overlap (mixing)
geposted Wed 06 Apr 05 @ 2:13 am
This issue is fixed in the upcomming 2.07
geposted Wed 06 Apr 05 @ 1:50 pm
Ok thanks to all I ill look out for the new version coming.And apopsis I will try yur method and see if it works thanks.
geposted Fri 08 Apr 05 @ 2:32 am
