are there any drop and drag type programs to make video effects to use with cue/vdj? or is it all script type writing?
geposted Sun 12 Jul 09 @ 12:42 pm
Really you need to be able to code in C++ and use the DirectX API.
geposted Sun 12 Jul 09 @ 5:46 pm
is this something easy to pick up? are there examples or something to follow like a tutorial?
geposted Mon 13 Jul 09 @ 2:19 pm
Depends on your aptitude at learning these things I guess; have you ever used C++ before?
geposted Mon 13 Jul 09 @ 3:33 pm
no but i pretty much self tought myself on any program i have ever used and i can use a bunch pretty well. i have never gotten into like html script writing or anything but i can still design sites and flash etc.
geposted Mon 13 Jul 09 @ 5:36 pm
Get yourself a copy of Visual C++ Express 2008 (it's free) and the DirectX SDK (also free) and see what you think. If you need anything I'm happy to help :)
geposted Mon 13 Jul 09 @ 6:52 pm
ok i got both installed. downloaded a sample project for sdk. which do i use to make the plugin or is there a basic way to start? thanks.
geposted Tue 14 Jul 09 @ 8:07 am
