How can I install/mapp my midi controler as a MIDI Sampler?
I know this could happen in the pro version, sorry for my newbieness (if that's word)
thanks!
thanks!
geposted Tue 21 Jul 09 @ 11:35 am
You can map the controls to use the sampler using the relevant VDJScript commands. Most of them are prefixed with 'sampler' :)
geposted Tue 21 Jul 09 @ 11:57 am
Thanks for your reply and support, but where do I get the VDJScript commands?
geposted Tue 21 Jul 09 @ 4:57 pm
Assuming that you are using the v6 trial, a full list of VDJscript commands can be found on the following page: https://virtualdj.com/wiki/VDJscript.html
geposted Tue 21 Jul 09 @ 5:31 pm
It is also very usefull to set your midi controller from the config menu of the VirtualDJ. You may assign an action to your controller by clicking an element on the skin you use. So you don't have to type or learn commands just use the skin you believe is closer to your controller.
geposted Wed 22 Jul 09 @ 10:41 am
I have version 5.7 and my midi controller is a m-audio Oxygen 8. As I said before, I'd like to use it as a controller for my samples and efects.
geposted Thu 23 Jul 09 @ 3:22 pm
