Hello
I was wondering if it will be possible in the future to have the option of having 4 decks skin.
I think a lot of people would love this?
geposted Wed 22 Jul 09 @ 8:21 am
Check the multi instance skins in the download section. There about 4 versions.
Not sure if they work in ver 6
geposted Wed 22 Jul 09 @ 9:31 am
4 deck skin is kidna difficult.
it would be easier to build a 2 skins and have you run vdj twice.
you can drag a file from one instance onto the other instance and it will work the same.
geposted Wed 22 Jul 09 @ 10:58 am
this is not new we ask for this for long time ago and multi instance is no good because you have to open two VDJ but on the second skin the database it dosent recognize the cues,bpm, i dont like this, 4 decks is on my dreams
geposted Thu 23 Jul 09 @ 12:57 am
does it take a lot of doing to re-cue the track, if the cues are not loaded from the databse? takes me just 1 second to do that. lol
geposted Thu 23 Jul 09 @ 3:23 am
we shouldn't need to analyze the db again.
at the same time.. you can drag a music file from the library of the 1st instance to the 2nd instance and it will load.
all you really need is a small skin with just the player function. and no db.
geposted Sat 25 Jul 09 @ 3:17 pm
