got V5 and its been working perfectly untill today when it crashed for no reason.
when i open it up if i type "A" "M" "P" etc it crashes, when i change the effects via numark total control it crashes.
Crash guard does nothing, simply doesnt open up ( even when i open on admistator)
And ive installed it again numerous times, nothing
any ideas????
any ideas????
geposted Wed 22 Jul 09 @ 8:34 pm
but do you have any crashguard reports? (in the crashguard file?)
(ps. register your serial number in your profile soon, too)
geposted Wed 22 Jul 09 @ 10:05 pm
Remove non-Atomix effects on the list.
I usually have this kind of issue before and it's totally solved when i remove those non-atomix plugin.
Maybe you can simulate it again scrolling into the effects via the total control then see in which effects did cause the software to stop.
geposted Thu 23 Jul 09 @ 1:53 am
Crash ID=004513de (date=907162348, version=5.0 rev.2 , build=502, thread=Main, dump=8b928c00, excode=c0000005 (0,8c))
Crash ID=0012f830 (date=907222008, version=5.0 rev.2 , build=502, thread=Main, dump=8f0546f8, excode=c0000005 (8,12f830))
thats my report, does that make any sence to anyone? lol
geposted Thu 23 Jul 09 @ 9:22 am
Please upgrade your Cue LE to the latest version.
To do this, go to https://virtualdj.com/users/edit.html and enter your Cue serial number in the box provided.
Then go to the Download Center to download the latest version: https://virtualdj.com/download/updates.html
geposted Thu 23 Jul 09 @ 11:57 am
