I've been using VDJ for a couple weeks (full version). I'm doing mash-ups. I've encountered a few problems:
1) The VJD Home edition's default skin doesn't seem to have the BPM on there (unless I missed it). Are there other "simple to use" skins; such as on the trial version? All I can find are the complex ones on the Downloads section
2) when I make samples and play them back with a song I've encountered two problems:
a) when I play the sample with the track (on the turn table) it's not loud enough. It doesn't make a difference if I adjust the sound levels on either the turntable or the sample volume
b) the sound is either not loud enough; very slow/fast. when I use a samlpe track while playing a song.
I hope all that made sense.
geposted Thu 23 Jul 09 @ 11:08 am
1) The BPM info should be visible near the track info.
2)a) The sample volume is a known issue and I believe it's being addressed.
b) Not loud enough, see a) above. Make sure the track that you are playing is properly analyzed for BPM and that BeatLock is ticked for the sample (bullseye icon above sample volume control).
I hope this information helps you ;)
geposted Thu 23 Jul 09 @ 11:30 am
