I WANTED VIRTUAL DJ To have a build in FADER CURVES
geposted Sat 25 Jul 09 @ 3:33 am
you can do that by VDJ 6.
"crossfader_curve"
select the curve of the crossfader. enter a value to adjust the slope from a X curve (0%) to a inverted-U curve (100%). you can also specify common curves by name ("smooth", "full", "scratch", "cut", "disabled"). or you can draw your own curve, using a syntax like 'crossfader_curve "0=[1,0]/0.5=[1,1]/1=[0,1]"'.
"crossfader_curve"
geposted Sat 25 Jul 09 @ 6:09 am
