first of all before i ask my question let say that i'm very aware of some of the burning programs out there that will alow you to burn the bin/cue files that VDJ uses to record a ready to burn cd file on to a disc ...there is roxio,fireburner,and nero. The problem with these programs are they cost money after the free trial is up...so my questions is
Does anyone know of any completly free of charge cd burning programs beside roxio,fireburner,and nero that supports burning of bin/cue files...if anyone knows of any programs like those that are free, please let me know....thank you
please remember i'm looking for a program that does not cost anything
fell free to let me know what burning program you guys are using to burn the bin/cue files with
geposted Sun 10 Apr 05 @ 3:13 pm
there are MANY free cd burning software out there, some really good ones too
http://www.sofotex.com/download/Multimedia/CD_Burner/
There are some free ones there
geposted Sun 10 Apr 05 @ 3:33 pm
thank you but do those programs support bin/cue files?
geposted Sun 10 Apr 05 @ 5:58 pm
lots of them do
read the description for each program
geposted Sun 10 Apr 05 @ 9:48 pm
the need for help is over, DJ in Norway is in town!!!, hehe
get yourself back on msn my friend,
geposted Sun 10 Apr 05 @ 10:02 pm
i looked over all the programs on this site and there wern't any that burns bin/cue files...that's why i asked the question again....i guess i just need to know what the other VDJ users are using to burn there bin/cue files
geposted Mon 11 Apr 05 @ 3:07 am
Why not just record as a WAV or use the MP3 plugin? Then you can burn your CD using whatever software you choose.
geposted Mon 11 Apr 05 @ 3:53 am
the thing about me recording to a wav or mp3 file is that my burner doesn't support disc at once so there is still a slight 0.5 sec gap in between the tracks...the only way for me to produce a no gap mixed cd is to use the bin/cue files ...i've used all the other programs during there free trial but the trials are up and so i'm looking for one that might be free.
geposted Mon 11 Apr 05 @ 1:06 pm
here is one :
http://cdmage.orcon.net.nz/frames.html
geposted Mon 11 Apr 05 @ 4:01 pm
