Just recieved my D-Vinyl 2020 and im not to crazy about there software all thoe it works well just dont like the way you can only use the controller to look up your music so i rather stick to VDJ ... the problem is when i run the software i get this error ( error in directx sound ) ... So i rebooted with the controler off still same error .. and the thing is once i get that error the program closes so i can change any of the config .. the version i have is VDJ 2.01 any help would be great ... thanks Dave
geposted Mon 11 Apr 05 @ 8:04 am
Ive download the new version 2.05 and the same error ????
geposted Mon 11 Apr 05 @ 10:07 am
lol dude, i dont know if the piracy staff has botherd to read this thred yet or if anyone else has either botherd with this, but buy a legal copy dude and it should work if not then the people here will be very happy to help you and any problems with the software.
Matty D
Matty D
geposted Mon 11 Apr 05 @ 10:30 am
The d-vinyl 2020 should set up in the sound card config using the Asio drivers. But this could not be done in the Demo version. So if you like to stick with VDJ you have to buy the full version.
As full version you will also get all the help you need on this forum...
Ewout
Ewout
geposted Mon 11 Apr 05 @ 8:42 pm
ezfilez
The latest version available is 2.06 Please download the demo or purchase the latest version legally.
geposted Mon 11 Apr 05 @ 8:47 pm
Will the software map to the buttons on the contoller or does it just use it sound .. thanks dave ..
geposted Tue 12 Apr 05 @ 6:03 am
@ Dave,
a) have you read the manual,
b) is your version legal
making sure both those things are true will help you a lot
Matty D
Matty D
geposted Tue 12 Apr 05 @ 9:19 am
