Hello,
Is it possible to create a keyboard shortcut for the effects?
eg: letter "r" for reverse or letter "e" for echo
If yes...please help
Thanks in advance for your help
geposted Mon 10 Aug 09 @ 5:57 am
Yes.
effect "backspin" active will toggle the backspin effect on and off for example.
geposted Mon 10 Aug 09 @ 1:51 pm
Sure!
Config -> Mapper
1) Go down and mark NEW
2) Press the button you want to configure
Type effect "flanger" active in the right upper field, called [Action:]
3) Press OK!
4) Thats it ;-)
But keep in you mind, the unofficial versions , are not so stable like the official ones ;-)
If you have a valid licence code, register your version under "Modify My Profile"
So you can download the latest Update Version of your bought software and join also the goodies;-)
See you
Haui
[Upps, i saved to late ;-]
Config -> Mapper
3) Press OK!
4) Thats it ;-)
See you
Haui
geposted Mon 10 Aug 09 @ 2:33 pm
Thanks mate..
You are a star......
geposted Mon 10 Aug 09 @ 2:34 pm
Ctrl+Left skip_beat -1
Ctrl+Right skip_beat +1
Ctrl+Shft+Left skip_beat -4
Ctrl+Shft+Right skip_beat 4
num- pitch -8
num+ pitch +8
shft+num- pitch -1
shft+num+ pitch +1
ctrl+num- pitch -306
ctrl+num+ pitch +306
num* pitch reset
ctrl+num* pitch_reset
Page up crossfader -128
Page down crossfader +128
Ctrl+Page Up crossfader 0
Ctrl+Page Down crossfader 4096
Shft+Page Up crossfader -16
Shft+Page Down crossfader +16
alt+space mix
ctrl+space automix
left skip_beat -4
right skip_beat +4
end skip_beat -1
pg.down skip_beat +1
home skip_beat -16
pg.up skip_beat +16
shft+left skip_beat temporary -4
shft+right skip_beat temporary +4
shft+end skip_beat temporary -1
shft+pg.down skip_beat temporary +1
shft+home skip_beat temporary -16
shft+pg.up skip_beat temporary +16
esc loop 0
41 loop 0
1 loop 1
2 loop 2
4 loop 4
5 loop 8
6 loop 16
7 loop 32
8 loop 25
9 loop 50
0 loop reset
shft+1 loop temporary 1
shft+2 loop temporary 2
shft+4 loop temporary 4
shft+5 loop temporary 8
shft+6 loop temporary 16
shft+7 loop temporary 32
shft+8 loop temporary 25
shft+9 loop temporary 50
shft+0 loop temporary reset
alt+1 goto_cue 1
alt+2 goto_cue 2
alt+3 goto_cue 3
alt+4 goto_cue 4
alt+5 goto_cue 5
alt+6 goto_cue 6
alt+7 goto_cue 7
alt+8 goto_cue 8
alt+9 goto_cue 9
alt+0 goto_cue 10
ctrl+1 set_cue 1
ctrl+2 set_cue 2
ctrl+3 set_cue 3
ctrl+4 set_cue 4
ctrl+5 set_cue 5
ctrl+6 set_cue 6
ctrl+7 set_cue 7
ctrl+8 set_cue 8
ctrl+9 set_cue 9
ctrl+0 set_cue 10
f1 sample 1
f2 sample 2
f3 sample 3
f4 sample 4
f5 sample 5
f6 sample 6
f7 sample 7
f8 sample 8
f9 sample 9
f10 sample 10
f11 sample 11
f12 sample 12
shft+f1 sample temporary 1
shft+f2 sample temporary 2
shft+f3 sample temporary 3
shft+f4 sample temporary 4
shft+f5 sample temporary 5
shft+f6 sample temporary 6
shft+f7 sample temporary 7
shft+f8 sample temporary 8
shft+f9 sample temporary 9
shft+f10 sample temporary 10
shft+f11 sample temporary 11
shft+f12 sample temporary 12
ctrl+F search
ctrl+back goto_last_folder
ctrl+V video_open
Hey dudes these r d shortcuts dude
from DJ DEVA
contact me : ****@*****
[Sorry, E-mail addresses and other contact details are not permitted for unlicensed users.]
num- pitch -8
num+ pitch +8
shft+num- pitch -1
shft+num+ pitch +1
num* pitch reset
alt+space mix
ctrl+space automix
left skip_beat -4
right skip_beat +4
end skip_beat -1
home skip_beat -16
pg.up skip_beat +16
esc loop 0
41 loop 0
1 loop 1
2 loop 2
4 loop 4
5 loop 8
6 loop 16
7 loop 32
8 loop 25
9 loop 50
0 loop reset
alt+1 goto_cue 1
alt+2 goto_cue 2
alt+3 goto_cue 3
alt+4 goto_cue 4
alt+5 goto_cue 5
alt+6 goto_cue 6
alt+7 goto_cue 7
alt+8 goto_cue 8
alt+9 goto_cue 9
alt+0 goto_cue 10
ctrl+1 set_cue 1
ctrl+2 set_cue 2
ctrl+3 set_cue 3
ctrl+4 set_cue 4
ctrl+5 set_cue 5
ctrl+6 set_cue 6
ctrl+7 set_cue 7
ctrl+8 set_cue 8
ctrl+9 set_cue 9
ctrl+0 set_cue 10
f1 sample 1
f2 sample 2
f3 sample 3
f4 sample 4
f5 sample 5
f6 sample 6
f7 sample 7
f8 sample 8
f9 sample 9
f10 sample 10
f11 sample 11
f12 sample 12
ctrl+F search
ctrl+V video_open
from DJ DEVA
geposted Mon 20 Dec 10 @ 5:41 am
How can I view what song is playing when I have my browser window open. I would like to identify it by saying "deck 1" or "A".
geposted Sun 24 May 15 @ 7:23 pm
Other than the display per deck displaying title - artist, you've also got, right click the field headings of the browser and select the "loaded on" field
geposted Sun 24 May 15 @ 7:55 pm
Thank you "Locodog"
geposted Wed 27 May 15 @ 10:20 am
HELLO ,CAN SOMEONE PLEASE INSTRUCT ME ON HOW TO MAP MY VIRTUAL DJ8 TO BE ABLE TO USE KEYBOARD SHORTCUT TO CHANGE THE ECCO LENGTH(EFFECT_SLIDER_2) PLEASE MAKE STEPS
geposted Sat 05 Aug 17 @ 10:04 am
1. Please don't shout
2. You are writing in the v7 forum - not the one for v8
3. Normally open a new thread for a new question instead of resurrecting old posts
But here you go:
The easiest is to use 2 keys or CTRL+ a key and ALT+ a key, to move in the opposite directions
In these examples I use CTRL+E and ALT+E
This will work for slider 2 for whatever effect is currently chosen, if it has a slider 2:
CTRL+E: effect_slider 2 -1%
ALT+E: effect_slider 2 +1%
If you want it to always be the second sider for the native Echo effect no matter if it's the current effect, you can use
CTRL+E: effect_slider 'Echo' 2 -1%
ALT+E: effect_slider 'Echo' 2 +1%
If you want it to also choose the echo effect as the current one when adjusting slider 2 you can use:
CTRL+E: effect_select 'Echo' & effect_slider 2 -1%
ALT+E: effect_select 'Echo' & effect_slider 2 +1%
You can of course map it to other keys, and you can also use another pct than 1%
If you choose to make it just for the echo effect, a bigger pct is relevant, because it's a step slider measured in bars
geposted Sun 06 Aug 17 @ 9:25 am
Please my DJ give me Good action of scratch in virtual
geposted Tue 02 Oct 18 @ 1:31 pm
Ways of effect setup on keyboard 🤔
geposted Tue 07 May 19 @ 12:23 am
