ok ive got
imac
maya 44 usb
behinger mixer
ion turntable
virtual vinyl
i have the turntable connected into the maya 44 inputs and the outputs going into the mixer... i have the maya 44 usb prefrences pulled up and the inputs are turned all the way up and not muted of course lol, and the inputs and outputs of my macs system prefrences set to maya usb.. now when i go to the virtual dj config ive got one timecode external mixer and 4out4in selected when i got to time code set up its not picking up anything it stays on 0%!! what am i doing wrong im going out of my mind
imac
maya 44 usb
behinger mixer
ion turntable
virtual vinyl
geposted Tue 11 Aug 09 @ 12:29 am
Don't have the Maya as your primary sound card on the mac; it will overwork the processor. Set up the maya 44 usb as an aggregate device and configure the aggregate device to be quadrophonic. you can search the forum to find instructions. After that it should work fine. It didn't work for me in v 5 but works fine on v 6 beta.
geposted Sat 15 Aug 09 @ 6:42 pm
Do you have the Numark Virtual Vinyl box or do you mean timecoded records?
Please note, Ion Audio is our consumer audio brand.
Ion Turntables are designed for Vinyl Conversion not heavy scratch use.
We recommend Numark TT500s or TX1s for this purpose
geposted Sun 16 Aug 09 @ 8:38 am
i set up the aggregate device but not sure what you mean by setting it up as quadrophonic. in anycase its still pumping zero percent its making a little noise now that ive done that but still 0.. i have the virtual dj timcoded vinyls
geposted Sun 16 Aug 09 @ 2:04 pm
I will post a how-to video tomorrow.
geposted Sun 16 Aug 09 @ 10:09 pm
thank you so much i would really appreciate that
geposted Sun 23 Aug 09 @ 2:28 pm
check out my how to video on the Maya 44. about half way through the first video I talk about setting up the aggregate device editor and making the speaker set up quadraphonic.
geposted Mon 24 Aug 09 @ 2:00 pm
ok dumb question i feel like such a novice....where is the video you posted?? i clicked your username thinking maybe its on your profile or something but no ...
geposted Fri 28 Aug 09 @ 2:20 pm
https://virtualdj.com/forums/114317/MAC_Version_Technical_Support/_TIMECODE__My_Video_on_setting_up_the_Maya_44_USB_on_the_Mac.html
geposted Sat 29 Aug 09 @ 11:54 pm
