When I try to start my trial version, I get the message, "Invalid skin file (error line 0 in the xml)". I pitched this question yesterday, and Teamer mp3jrick said,"Actually, your various demos have been killed by that crack you loaded, and that is where that skin error is coming from, not the demo." While that explained it, I wanna also know how to fix it.
geposted Fri 14 Aug 09 @ 12:04 pm
Purchase the software ...
geposted Fri 14 Aug 09 @ 1:45 pm
I have purchased the software and i am geting the same problem, does having vista mean that it wont work?? if not how do i fix this problem??
geposted Fri 14 Aug 09 @ 1:58 pm
I will, whenever $300.00 magically appears into my wallet. Since I need new skis, it's not bloody likely.
Really I just wanted to try this out. the initial trial I got shut down within a minute (Have no clue why) and now none of them work.
geposted Fri 14 Aug 09 @ 6:37 pm
Here is a free solution:
1. uninstall the cracked VDJ
2. install iTunes or Winamp
3. do some gigs, make some money and buy the software or keep the proffits you now leagally earned, for yourself
Honestly, I have DJ'd a wedding with iTunes and did just fine. I even got a tip at the end. It was hard work and I wished I could afford VDJ at that time, but I could not. That is life and life sucks sometimes. Did your parents teach you that you could have anything you want at any time?!
Would you go to Guitar Center and compain to them about why they will not waranty a CD player that you stole? Same thing dude!
geposted Sat 15 Aug 09 @ 7:25 am
i'm getting the same error. i upgraded my laptop from xp to 7 and downloaded 6.03 from the vdj site. whats the problem?
geposted Thu 28 Jan 10 @ 1:04 pm
thanks that did it.
geposted Thu 28 Jan 10 @ 5:23 pm
You're welcome
geposted Thu 28 Jan 10 @ 5:57 pm
I am still having the same issue. I have posted this a while ago, and
tried the registry tool. Unfortunately I still don't know what I am looking for.
https://virtualdj.com/forums/122065/PC_Version_Technical_Support/crash_report_ver_6_05.html?search=crash%206.05&page=1
Can anyone her give me some tips, please?
geposted Fri 29 Jan 10 @ 10:28 am
Rick,
Thanks;
Yes initially it was a crash report. That stopped after reinstall.
Then I started getting the line error. According to Cel it is a
skin issue. He said to use the reg tool and paste it.
I have deleted as you said numerous times, with the same results.
I really do not know what I am looking for in the reg tool results.
Just for kicks I uninstalled again and same results.
Thanks;
geposted Fri 29 Jan 10 @ 12:08 pm
geposted Fri 29 Jan 10 @ 12:37 pm
