Hi
Is their a way i can set VDJ to 1280x1024? Can i modify some file to enable it for me?
Thanks
Flame
Thanks
Flame
geposted Tue 12 Apr 05 @ 8:35 pm
Some skins are made for 1280x1024. Converting the scale and the ratio of a skin is HARD TIME babe!!! but possible if you do move ALL the buttons. Good luck.
FRUiT94
FRUiT94
geposted Tue 12 Apr 05 @ 8:50 pm
Did you just call Flame, "babe"?...LOL
Yeah, if you are converting a skin you might as well make a brand new one. If you have the original PS (or other) file, I guess it wouldn't be that bad (for the graphics side)...but a BMP doesn't help.
geposted Wed 13 Apr 05 @ 12:33 am
ok, th dudes, sounds like work (hard) let me know if u have some...
geposted Wed 13 Apr 05 @ 10:37 pm
