I'm considering purchasing Virtual DJ but I want to know if it will operate with PCDJ's external mixer which I received as a gift. If you've worked with the combination of the two, I'd love to hear how they work and if it makes mixing easier.
Thanks
Thanks
geposted Wed 13 Apr 05 @ 2:25 am
Which model?
The Numark DMC-1 will work with an upgrade chip from www.gizmolabs.net
The Visiosonic DAC-2 will work without modification
Oh, you need to buy the full version of VDJ first!
geposted Wed 13 Apr 05 @ 2:29 am
It's the dac-2 model.
geposted Wed 13 Apr 05 @ 2:32 am
DAC-2 is supported by Virtual DJ
You need the full version, and the controller plugin app that is downloadable for full users
geposted Wed 13 Apr 05 @ 3:14 am
@Gambit39
Here is a post where I talk about using the DAC-2 along with the TimeCoded Vinyl.
https://virtualdj.com/forum/display.html?topic=10834
But I will tell you that with the DAC/DMC Mapper Plugin, you will like the control you have of the software and the mixing.
Look forward to seeing you as a full version user!
cstoll
cstoll
geposted Wed 13 Apr 05 @ 4:34 am
Thanks for your input. That will give me a push towards buying it since I can use it with something I already have.
geposted Thu 14 Apr 05 @ 1:40 am
hope to see you as a full member soon :)
geposted Thu 14 Apr 05 @ 4:36 am
