Hello, I'm a new user of hercules with vdj. Everything works well.....But I think the auto beat feature does not match and mix totally on beat.
Am I doing something wrong ? I also cannot cue and mix in manuel mode.....Am I doing something wrong again.....I do mix very well on standard audio dj equipment but like the idea of doing it on my pc...
Any help would be appreciated
Thanks
Thanks
geposted Wed 13 Apr 05 @ 3:55 pm
What version are you running there Giorgio?
geposted Thu 14 Apr 05 @ 12:05 am
Hello
Plz disable your firewall,go to your profile and VDJ will detect your DJ console
also if you need info go here:http://www.virtualdj.com/forum/display.html?topic=10347
Regards
Andre
Regards
Andre
geposted Thu 14 Apr 05 @ 4:46 pm
