Hey. Im looking for a MIDI controller with good jog wheel, that would make it possible for me to make realistic scratches. I found a cheap one called uSolo ( http://www.djtechmart.com/cart-eu/C-MP-uSolo.html ). Anyone knows if its compatible with CUE LE or VDJ?
Maybe You can recommend a MIDI controller that could suit me. Thanks.
geposted Thu 20 Aug 09 @ 7:09 am
https://virtualdj.com/forums/114065/Hardware_Technical_Support/Combining_Ion_Icue_with_UC33E_on_Virtual_dj_.html
With VDJ PRO, you can use/control neraly every MIDI Controller.
The only thing you should keep in your mind, you need a mapper and a definition file.
In the Download Area (PLUGINS -> Tools & Drivers) you can see a selection of the present mappers ;-)
Also at Hardware products!
For non listed Hardware, you must build a own mapper and definition file ;-)
Haui
Haui
geposted Thu 20 Aug 09 @ 7:58 am
oki thanks. But for mapping your own stuff you will need to have programming skills, right? :)
geposted Thu 20 Aug 09 @ 8:07 am
Not really, if you follow the steps or explainations! ;-)
https://virtualdj.com/wiki/VDJscript.html
https://virtualdj.com/wiki/ControllerDefinition.html
geposted Thu 20 Aug 09 @ 8:32 am
From what I can tell, the uSolo is not a MIDI controller. It's a stand-alone USB media player (I.e: Plays music directly from a USB memory stick or hard disk.)
geposted Thu 20 Aug 09 @ 12:16 pm
