Forum: Old versions
Topic: Please help
Hi,i own a BCD3000 and i'm planning to buy a pair of Pioneer cdj200s or Stanton C.314
Well,i just want to know if i need a soundcard???
or is it possible to connect the cd players via the BCD3000 and use it as a soundcard??
Thanks.....
geposted Sat 22 Aug 09 @ 10:20 am
hi ya, I would steer away from the cdj 200 as they do not have scratch so you wont be able to move the track around to cue it with the jog wheel. I would save up for a set of denon 1200's with a DJio soundcard. Ditch the bcd3000 on ebay to fund the soundcard. good luck chap
If you mean Denon DN-S1200's, then you don't need a separate sound card with these because they have one built into each player.
Another good choice is Pioneer CDJ-400 if you are looking for Pioneer CD players - These can act as a MIDI controller for VirtualDJ.
Wat about the Stanton C.314??
The jog wheel is able to scratch,will it work??
And u mean i cant use the BCD3000 as a soundcard??
It's not a MIDI controller, so it cannot directly control VirtualDJ.
However, with a suitable 4-in/4-out ASIO sound card such as Native Instruments Audio 4 DJ or ESI Maya44 USB, it can be used with timecode CD to control song playback: https://virtualdj.com/products/timecode/cd.html
Its still not clear in my mind sorryy......
I'll try to make it a simple question
I own a BCD3000 and im planing to buy two cdj soon.
I want to connect the cdj to the BCD3000.
I want to know whether i can use da BCD3000 as a mixer and a soundcard as its integrated in it??
I just want to use the cdj with timecode cd connected to my BCD3000 via my laptop and vdj.
Will it work??
or do i need to buy a soundcard and a mixer??
