Hey!
I was wondering if you can rotate the CBG lines.
What I mean by this is: instead of the CBG lines looking like this:
l l l l l (Horizontal)
l l l l l
Can you edit the code so the CBG lines look like this?
-- -- (Vertical)
Thanks!
PS: I know I am unregistered but please help a brother out? I plan to buy the full version as soon as I get the money.
Thanks again!
l l l l l
-- -- (Vertical)
Thanks!
Thanks again!
geposted Mon 24 Aug 09 @ 4:46 pm
Hi,
The CBG in the Rhythm view cannot be changed to vertical.
But if you are talking of a "beatkeeper" as seen in the top middle of VirtualDJ v6 skins, then yes you can make that vertical.
Each beat rectangle is defined with the deck number, "goto_bar" and a number:
deck 1 goto_bar 1
deck 1 goto_bar 2
deck 1 goto_bar 3
deck 1 goto_bar 4
So you can place these rectangles anywhere you want.
deck 1 goto_bar 1
deck 1 goto_bar 2
deck 1 goto_bar 3
deck 1 goto_bar 4
geposted Mon 24 Aug 09 @ 6:09 pm
Well i can not understand how you could use horizontal cbg but i think that you may change those lines from the rhythm element..
Now if you change for example height="1" and wdth="30" and mainwidth="50" maybe this would look like horizontal to you. But i still cant get the point of this.
Quote :
<grid1 width="4" mainwidth="11">
<size width="1096" height="4"/>
</grid>
</grid>
geposted Mon 24 Aug 09 @ 9:13 pm
From what I understand, the user wants to have the CBGs vertical like in the bottom part of this picture:
geposted Tue 25 Aug 09 @ 1:30 pm
This makes sense.
geposted Tue 25 Aug 09 @ 4:02 pm
The reason I would want my CBGs to be vertical, because I've borrowed serato from one of my best friends. I recently gave it back.
Anyway, I want my skin to have an impression of serato. It would be nice if the CBG lines could go vertical, so it could look even better, when I position the CBG lines with the scratchwaves..
geposted Wed 26 Aug 09 @ 1:11 am
