Hello all! I get an "error in video driver" message. I've tried to delete and download again, with same results. Any ideas? Using version 6.01
geposted Thu 27 Aug 09 @ 8:37 am
Hey I keep getting the same problem too!
Sometimes its a 'on' 'off' thing.
It would say "Error in video driver" for like a couple hours and then it wouldn't say it anymore.
Another thing I do is restart my computer, and I could use Mix Lab again..
I hope someone would tell us why this happens.
geposted Thu 27 Aug 09 @ 12:40 pm
I don't understand what this could possibly have to do with a Skin.
My suggestion would be to go into config and ensure that in the video tab you have the output set to the correct setting. i.e. if you want it in the Window - select window, likewise for external display - select said display.
If problem persists please supply some more information - system specs etc.
I am 99% sure this isn't a skin issue.
geposted Thu 27 Aug 09 @ 12:50 pm
check your directx is installed and/or upto date, do you have c++ installed ? if not do it, could also be settings have changed from the last time you used it.
geposted Thu 27 Aug 09 @ 1:59 pm
I don't have the same issue with other skins....just this one.
geposted Thu 27 Aug 09 @ 4:04 pm
