Forum: Old versions
Topic: Computer Specs
Hi all, I just wanna ask you about the computer specifications needed to run VDJ without sound drops and stuff like that.
I mean, can i run on a computer with a cpu @ 2 ghz, 2gb of ram? I really dont want to spend a whole lot of money buying the most expensive computer if I can get a computer for a lower price, and still it runs really good.
And yes, i will only use it for vdj use.
Thx in advance, tobbe
geposted Thu 27 Aug 09 @ 10:59 am
Dual core, 2 gigs ram this will run VDJ well. If you plan on doing any video make sure you have a good quality videocard
https://virtualdj.com/wiki/Specifications.html
MINIMUM REQUIREMENTS
The minimum requirement to run Virtual DJ is:
* PIII 850 MhZ computer
* 1024x768 SVGA video
* DirectX compatible soundcard
* 512 MB RAM
* 20 MB free on the hard-drive
RECOMMENDED REQUIREMENTS
The recommended configuration is:
* PIV 3 GhZ computer
* 4.1 DirectX compatible soundcard (with front and rear separate outputs)
* 1024 MB RAM
* 200 MB free on the hard-drive
RECOMMENDED VIDEO MIXING REQUIREMENTS
The recommended configuration to mix video is:
* Dual Core 2 GhZ CPU
* dual output ATI or nVidia video card with 1Gb of on-board memory (no integrated laptop videocard)
* 2048 MB RAM
