Has anyone else here had an issue with fluctuating key and pitch with 6.0.7? Just to make sure I wasn't going crazy I tested this out on the Mac version as well and I went back down to 6.0.5 and it worked just fine.
geposted Thu 11 Mar 10 @ 3:06 pm
yes I too am experiencing this on dnhs5500 with 6.0.7, how they have managed to take a perfectly good working version of VDJ and screw it up I have no idea, does anybody actually test these updates on the hardware or are we all just beta testers
geposted Sat 20 Mar 10 @ 7:06 am
Hi dj john we are having the same problem as you with the denon HS5500 we cant get the midi to work, when we connect the denon up to the computer then go the press the midi it shows red not green press the config and actervate still dont work. did you get yours working in the end or not if you did what did you do.
geposted Sat 20 Mar 10 @ 3:44 pm
This is because you are using it with an out-of-date and most likely illegal pirate version of the software.
Please use it with the latest trial https://virtualdj.com/download/trial.html
And if you are using it illegally, please support the software and its future development by purchasing it: https://virtualdj.com/buy/
geposted Sun 21 Mar 10 @ 3:51 pm
@finga73
Also are you having the issue when you press the Layer button to switch "other" deck does playback stop completely on Layer 1? I just went back to 6.0.5 since I wanted to shoot myself over crappy audio and no dual layer support for our deck. I created a ticket about the issue but i haven't heard anything about it for the last 10 days so I updated it.
Have you heard anything?
geposted Tue 23 Mar 10 @ 10:28 pm
bump.
geposted Thu 25 Mar 10 @ 10:11 pm
bmonserud wrote :
@finga73
Yep, thats exactly the problem I experienced, went back to 6.0.5 immediately too, which works fine, also I experienced the old warbling problem from previous versions with early 5500 native support
geposted Fri 02 Apr 10 @ 6:59 am
Hi John
Any chance you could shine some light on how you have the fireface UC setup .. im using timecode vinyl setup with external mixer but cant for the life of me figure out the routing on the fireface mixer page .. im getting sound from both decks coming through on one channel of my external dj mixer ? Any help would be greatly appreciated .- or even a template would be amazing ! Im working with Mac.
geposted Thu 19 May 11 @ 6:22 am
Sorry, I'm using the fireface 400. It's a diferent soundcard. I'm also not doing timecode and I'm on a PC not Mac. I would start with the sound setup and play around with that.
geposted Thu 19 May 11 @ 6:47 am
