Has any tried the denon s3700 with vdj6.0.2. Any difference or improvements? And what are the beat settings possible for scratching? Thanks guys.
geposted Sun 30 Aug 09 @ 3:24 am
The 5500 and 3700 are the same platter technology ... and yes it is fixed ... see here for best settings ...
https://virtualdj.com/forums/114889/Hardware_Technical_Support/VirtualDJ_6_0_2___Denon_DN-HS5500.html
geposted Sun 30 Aug 09 @ 8:42 am
Thanks cstoll. I just have one more question. Are the scratch settings for my s3700 going to effect the platter settings on my hc4500?
geposted Sun 30 Aug 09 @ 12:38 pm
The settings in Options are universal ... but they should be good for the 4500/5500/3700 controllers.
geposted Sun 30 Aug 09 @ 1:04 pm
Does the latest firmware for the s3700 and hc4500 make a difference with version 6.0.2 becuase I dont want to upgrade them if there is no difference or improvement with the 6.0.2.
geposted Mon 31 Aug 09 @ 1:58 pm
Depends on how you are using the controllers ... but upgrading & downgrading the firmware is easy. You can always reverse things if the new gives you no benefit.
geposted Mon 31 Aug 09 @ 2:15 pm
Well I am going to use the hc4500 as my main controller and the s3700s just for scratching.
geposted Mon 31 Aug 09 @ 2:57 pm
Would suggest upgrading the firmware in the 4500 then ... :)
geposted Mon 31 Aug 09 @ 4:30 pm
