Hi, I just bought the new version and Im suffering extreme warbling when using the spinning platter in MIDI mode, the LCD and everything is working but the sound whilst using it is terrible, sounds like I keep rubbing my finger on the side of the platter causing it to warble like crazy, I tried the default settings and the new slider settings posted by cstoll in the thread below and no difference, tried to change my ASIO latency also but still to no avail, any ideas?
edit, jog trns setting on player was at 1ms as advised on denon boards for xp OS, have set it to 3ms and its improved x100
geposted Sun 30 Aug 09 @ 6:07 am
so 'improved x100' means no warble ... or it's still there just not as noticeable ?
geposted Sun 30 Aug 09 @ 8:41 am
played for an hour or so, no more warble, sorry forgot to post back, was enjoying it too much
geposted Sun 30 Aug 09 @ 8:59 am
hi there is 6.0.2 out? I tried to download the trial and its still 6.0.1? I have 5500 and want to use mine, i too get awfull wow and flutter on 6.0.1 can you please confirm what your using, thanks
geposted Sun 30 Aug 09 @ 10:35 am
6.0.2 is only for PRO user, DEMO is still 6.0.1
geposted Sun 30 Aug 09 @ 10:38 am
For VDJ 6.01 / 6.02,
For XP/MAC, set the "Jog Trans" to 3ms (found in the S3700/HS5500 preset mode), 1ms will give you wobble sound.
For Vista, set the "Jog Trans" to 10ms (found in the S3700/HS5500 preset mode)
geposted Sun 30 Aug 09 @ 12:37 pm
I just posted in this topic but its about this anyone
https://virtualdj.com/forums/110440/Hardware_Technical_Support/DENON_Hardware_Products_%28Setup__Solutions__Fixes__Issues__etc_%29.html
geposted Tue 01 Sep 09 @ 2:40 pm
