Is it possible to set shortcut on keyboard to set (enable or disable) "jogs to scratch" function in Hercules DJ Console setup?
tnx
Dj Nikki
tnx
Dj Nikki
geposted Sun 17 Apr 05 @ 10:53 am
That is my DREAM!
geposted Mon 18 Apr 05 @ 5:12 am
this is possible yeah....
go to the shortcutmap in the configuration, and select pannel.
you have to look what pannel it is in the xml file...
see my blog....i will add it now.
geposted Mon 18 Apr 05 @ 5:57 am
i tryed your skin, but i can't find the same text in xml file of it. am i doing something wrong?
where is the button fot this function in your skin?
tnx
tnx
geposted Mon 18 Apr 05 @ 3:50 pm
i dídn't upload that one...you have to look for another skin...
geposted Mon 18 Apr 05 @ 4:15 pm
i like only a few skins. is it possible just to built in this function in another skin? i mean.. can i built this function by myself in skin that already exist?
geposted Mon 18 Apr 05 @ 4:21 pm
yep...but i think you better send me a skin or tell me what skin and i will fix it if you want..
becouse telling you how to do is not simple..
geposted Mon 18 Apr 05 @ 6:52 pm
@djjb i will be grateful if you can help me with this. Contact me on msn when you'll have time.
thanks
Dj Nikki
thanks
Dj Nikki
geposted Tue 19 Apr 05 @ 10:14 pm
I agree, this is a good idea -- I am sick of going into the config to change it
geposted Wed 20 Apr 05 @ 2:43 am
@djjb THANK YOU VERY MUCH FOR HELP! Buttons are working correctly! You are the best! :P
geposted Wed 20 Apr 05 @ 7:58 pm
@djjb
crossfader(6000) is not correct !!
The max is in fact 4096 like all the sliders so you should write crossfader(4096)
It works because 6000>4096 but it's not very beautiful ;-)
geposted Wed 20 Apr 05 @ 8:17 pm
thanx djcel....i will change that.....
geposted Wed 20 Apr 05 @ 8:47 pm
