Hey
I have licenses my RMX, but can,t download new v1.3 mapper, i dont have money to buy vdj pro, so i want to edit the xml. Which i can do partially...
I did :
<map value="BALANCE" action="djc_button_slider 1" />
<map value="PFL_MIX" action="djc_button_slider 2" />
It works but i lose my balance and monitor headphone ( which is really important to me )
I wanted to map like this :
<map value="SCRATCH+BALANCE" action="djc_button_slider 1" />
<map value="SCRATCH+PFL_MIX" action="djc_button_slider 2" />
So when SCRATCH would be ON + use BALANCE or PFL_MIX it would do action, but i ran out of luck. it doesnt work
I would like to use deck 1 jog wheel = djc_button_slider 1 and deck 2 = djc_button_slider 2.
when scratch button is ON so i dont lose my jog wheel to mix music...
But I dont want scratch effect when slider 1 or 2, i could remove scratch function (vinyl mode, i dont care)
Or any other mapping idea(s) on this would be appriciated
Anyone can help ?
I did :
Anyone can help ?
geposted Fri 04 Sep 09 @ 12:19 pm
Why dont you try this:
vinyl_mode ? balance ? djc_button_slider 1
vinyl_mode ? pfl_mix ? djc_button_slider 2
I will install LE on another machine and test some other things out...
geposted Wed 07 Oct 09 @ 12:01 pm
