I can't remember how I did this b4 .......
Norway turned me on to a cool VST plug in from Kjaerhaus Audio their Classic EQ .......it's a free download
it works differently than the other fx and I can't get it to work , i have redownloaded it to a new system is the problem ....
much obliged for any help , you wimps
geposted Sun 06 Sep 09 @ 5:49 pm
If memory serves Chuck, go to My Documents/VirtualDJ/plugins/soundeffects and paste the VST plugin you wish to use there.
geposted Sun 06 Sep 09 @ 6:06 pm
Thanks Tear , hope yer having a great holiday weekend
I already tried that ......
geposted Sun 06 Sep 09 @ 6:21 pm
OK, after looking at mine, you need to paste both the .dll and the config settings need to be pasted into the sound effects folder. Then you would need to turn on the EQ from the effects portion of VDJ. Does that help?
geposted Sun 06 Sep 09 @ 7:24 pm
thanks i don't have the .ini ....... it didn't download ??
geposted Sun 06 Sep 09 @ 7:54 pm
Was it a .zip file? If so you might be able to decompress it with an .rar (after renaming it to a .rar from a .zip) program, then copy paste the two elements.
geposted Sun 06 Sep 09 @ 9:33 pm
it is zipped but it only has the .dll and a read me pdf .......??
geposted Sun 06 Sep 09 @ 9:39 pm
Check your PMs, big guy...
geposted Sun 06 Sep 09 @ 9:42 pm
thanks Tear ......I don't care what everyone says about you moderators, yer awright ..........
geposted Sun 06 Sep 09 @ 10:45 pm
