Does anyone using Pioneer cdj 400 and Behringer DDM4000 simultaneously ?
I do, and have run in to multiplle problems. Like when cueing up the 400 will activate the kill switch. Also the PFL will not work on the mixer.
I see a thread on the last issue, but i i dont like the idea of de-activate the crossfader. (but will do if this is the only remady). Also the kill switch problem is annoying.
Can annyone give me input on how to solve the problem when we combining the two unit.
Also I like everyone who use the two unit to bee in this thread.
geposted Tue 08 Sep 09 @ 11:12 am
Actually you can use the 400 as controller only mapping a few buttons on the DDM. You can get a good Idea on how to map it by viewing Rude's tut video.
here it is
https://virtualdj.com/forums/115295/Hardware_Technical_Support/Pioneer_cdj_400_help.html?search=CDJ%20400&page=1
BTW I know he is using the DJM800 but you will get the Idea on what you need to do..
here it is
geposted Tue 08 Sep 09 @ 11:47 am
