Hi, im planning to use M-audio's x session pro on my vdj and my laptop. what are the basic problems should i expect to encounter? im using Vista Basic as My OS will this work? hope anyone can answer.
geposted Wed 09 Sep 09 @ 1:19 pm
it will work
geposted Wed 09 Sep 09 @ 9:47 pm
I just purchased the X-session pro as a backup and when I plug it in the program recognizes it but the problem I have is that the mapper buttons are all wrong. None of the buttons work the way they should. How do I fix this problem
geposted Thu 10 Sep 09 @ 8:12 am
Its easy, just select the key in config/mappers/xsession and change the script in the box to the right.
It will suggest, but if you look in the wiki you will find common scripts to achieve what you want to do.
geposted Thu 10 Sep 09 @ 8:19 am
I was trying that method but I couldn't get the commands to stay for each button. maybe I was doing something wrong. Do I have to save it after every button or can I do the whole device at one time? I will give it a try it again.
geposted Thu 10 Sep 09 @ 11:07 am
The following has sort of worked for me:
1 Select "Config" > "Mappers"
2 Choose M-Audio/Evolution X-SESSION at top
3 Click "{new}" at bottom of left-hand column. Then press button on controller. Then Type action in Action field
4 Repeat step 3 for each button on controller
5 Press "OK"
Two problems, one of which I may have solved, the other I would REALLY appreciate any help anyone has:
First, with the default set of x-session pro MIDI signals, VDJ seems not to be able to recognize the buttons, even though it does fine with the faders. It turns out the xsession has 10 sets of MIDI presets. They are changed by pressing the "A" button on the back of the unit with a pen or paperclip, waiting 2 seconds, and then pressing a controller button. I am now using the preset realized by pressing the right arrow button on the left deck (after pressing "A").
Although my bottons are now working, functionality is limited. In particular, I can't seem to get anything attached to holding the buttons down. So commands like "cue_play" don't work. I also can't get any assignment that reasonably lets me jog backwards or forward through the track (transit controls).
PLEASE HELP IF YOU HAVE ANY ADVICE!!!
It is very frustrating to have to do all my transit with the mouse. And please don't say the solution is to buy a more expensive controller ;)
5 Press "OK"
geposted Wed 23 Sep 09 @ 5:43 pm
I have the x session pro. how can i map it so both side work? i can only work one side of the mixer.. please help!..thank you
geposted Fri 12 Mar 10 @ 1:06 am
just type it in. my problem is the pitch faders are inverted I cant figure this out. Another problem (off topic) is that my serato vinyls cut off tc sometimes.. but if anyone can help w the fadewr problem pls advise! thnks
geposted Mon 29 Mar 10 @ 5:09 pm
You will need to add param_invert, e.g:
param_invert & pitch_slider
For further information, please see:
https://virtualdj.com/wiki/VDJScript%20Examples.html
https://virtualdj.com/wiki/VDJscript.html
https://virtualdj.com/wiki/VDJscript_verbs.html
NOTE: In the trial, timecode is limited to 10-15 minutes per session and will stop working after that until you restart the software.
geposted Tue 30 Mar 10 @ 12:49 pm
