Forum: VirtualDJ Skins
Topic: Smaller Skins
Hi there
I just signed up to the forum today but been playing round with virtual dj for a few months
I've only ever used the mixlab3.1 skin
I recently got a new laptop, one of those small ones, and the max resolution is only about 1024 x 600 I think
Is there a smaller version of the mixlab3.1 skin? or is there something similar I could use on my laptop instead?
I can manage using the mixlab skin but have to centre it and move it if i want to adjust the speeds etc (the controls on the edge of the skin)
Thanks in advance
geposted Mon 14 Sep 09 @ 8:34 pm
JeremKPRO InfinityModeratorMember since 2004
Hello,
If you register VirtualDJ in your profile: http://www.virtualdj.com/users/edit.html
you will be able to download all skins and the Skin Resizer tool that will let you resize the mixlab skin to 1024x600.
geposted Tue 15 Sep 09 @ 3:14 pm
