Forum: Old versions
Topic: Multi-Instance_Skin_variations
Hey there this forum is to get some info on the multi instance skin variations. This seems to be the only solution to get four decks on virtual dj. If your using it or ever had used i want to hear from you. Can you use it with virtual dj 6? Can you control it with one controller? or do you need two? Are you scratching? video? with time codes? what sound card?
Thanks =?
geposted Thu 17 Sep 09 @ 1:02 am
link to the skins description/download page
https://virtualdj.com/addons/967/Multi-Instance_Skin_variations.html
hit me back with some real experienced info on this skin. Wanting to know... how to use it? how to use the multi instance beat sync so to get all 4 decks on beat? I heard you need 2 controllers. 1 for each instance. Is this true? Are you scratching on at least two of the 4 decks? also hows the video? Does running so much stuff slow down program?
Wanting two know all if this because i am trying to get 4 decks controlling video in virtual dj. Two of the decks controlled by time coded vinyl so to scratch video. The other two controlled by an external mixer or midi, also doing video.
let me know thanks =?
