Hey there is a way to get 4 decks with virtual dj and its the MULTI-INSTANCE_SKIN_VARIATIONS.
Here is a link to the description and download page
https://virtualdj.com/addons/967/Multi-Instance_Skin_variations.html
i haven't had the time so far to mess with this skin so i don't know much about it which is why i started the forum
If you have used it i want to hear from you. How it works? HOw to get all 4 decks in sync with each other? Can you use it with virtual dj 6? Can you control it with one controller? or do you need two? Are you scratching? video? with time codes? what sound card?
Any and all info on this skin would be dope
thanks =?
thanks =?
geposted Sun 20 Sep 09 @ 1:32 pm
man no one know $h!t about this skin i started 2 forums about it no one commented. I guess its up to me to learn how it works i will post stuff latter about what i find out.
But if you still have any info let me know
yo thanks and keep spinning =?
geposted Mon 21 Sep 09 @ 12:30 pm
I've copied your post and my reply to your other thread on multi-instance skins in the skin forum.
https://virtualdj.com/forums/112554/Virtual_DJ_Skins/Multi-instance.html
In future please do not make multiple posts on the same topic to try and get attention.
Topic locked :)
Regards,
Scott
Topic locked :)
Regards,
Scott
geposted Tue 22 Sep 09 @ 4:29 am
