Ok, i know i should RTFM ;-)
Just one thing i have been thinking about .
Is it possible to controll all the important functions
in VDJ via a plugin to do a hardware mapper to a console/controller
like Hercules, Behringer etc.
Let's assume that i already have solved all communication
to the hardware and just want to controll VDJ.
geposted Fri 22 Apr 05 @ 7:59 am
Yes you can.
But, for this type of hardware controler (sending midi commands), you can also use keyboard shortcuts.
geposted Fri 22 Apr 05 @ 8:47 am
Great,
This is an idea i have for a first plugin project:
Since i also do a lot of hardware design etc i'm thinking of building a really cheap "PRO" Controller and interface it via the LPT port to the computer. Then map that to VDJ via plugins.
I always use an external mixer with VDJ so i don't need "console" functionality, just a dual controller.
I could also use USB but that is a little bit more work.
geposted Fri 22 Apr 05 @ 9:14 am
