I need some assistance.
I tried setting a shift key and I'm not getting it right.
This is what I trying to do:
I want to change the buttons by the jog wheel (default is autobeat) that when I press (like shift) I can do the following:
* Alternate between the default pitch knob and adjust the gain
* Delete the cue points 1-3
The MK2 is default settings.
Thanks in advance.
FLeX
Thanks in advance.
FLeX
geposted Wed 23 Sep 09 @ 10:03 am
Please see https://virtualdj.com/homepage/jpboggis/blogs/3702/VDJscript_examples.html for information on how to map a SHIFT button.
geposted Wed 23 Sep 09 @ 12:28 pm
I just want to say thank you. I fixed the gain easily.
Off and on I worked on figuring out the cue with delete & figured it out. " I could had a V-8..."
geposted Sat 10 Oct 09 @ 12:04 pm
