-)) Hi All !! My name is KriSSie. And I'm posting from NZ.
Just an inquiry, my Brother has tried the Demo version of this programme.
And is really interested in buying the Full Version. The only problem is,
he isn't connected to the Internet. He was able to load the free Demo from
a PC Magazine (Disc) here in NZ. I'm connected to the Internet, and was
wondering, is it possible to pay for it on my PC. Download it & transfer it
to his PC ?? Is that possible ?? And if Yes, how would you go about it ??
Any help would be much appreciated =) ...
Thank You ...
KriSSie
Thank You ...
KriSSie
geposted Fri 22 Apr 05 @ 9:47 am
Hi i'm in christchurch NZ
To answer your question yes and yes.
VDJ is easy to buy and costs about $180 NZ
you can use all sorts of methods, although not all are instant.
Check out the Buy Section, easiest is if you have credit card or a friend thats got one and just give them the money.
You need an Email address and VDJ will send you a link to download the program.
The link is valid for a limited period but will allow you to download more than once .
You can Save the downloaded program to disk and install on any computer you own.
But only you are licecensced to use it or a friend on your computer.
What I mean is you cant load it on multiple machines and have different people operate it at the same time for example running multiple rigs, you then need a lisence for each computer.
Welcome to virtual Dj look forward to seeing you on these forums as a reg. user.
geposted Fri 22 Apr 05 @ 12:32 pm
To download VirtualDJ you need to let your mail so the software should be yours. It's better, to my mind, to explain that to the e-service. They could find the best solution for you and your brother.
geposted Fri 22 Apr 05 @ 8:01 pm
my virtual dj is just sticking on all my loops and fx not playing at all,need a response cos this is doing my 'ead in!
geposted Sat 23 Apr 05 @ 9:38 pm
Write your config into your Blog to get better and faster help
geposted Sat 23 Apr 05 @ 10:38 pm
i need to download virtual dj 3.1 on my desktop and make it stay there. Is there a version of virtual dj i can download with out a 20 day trail.i need a version that can stay on my desktop
geposted Sun 20 Nov 05 @ 6:14 pm
Dominic,
you could download a demo, that works for 20 days. This version is intended for testing purpose and to have the abillity to see if you like the programme.
After you have tried the application you could buy the software. You will be able to download a version which you could use forever.
Ewout
Ewout
geposted Sun 20 Nov 05 @ 6:23 pm
Dominic, also please note that you can install VDJ on ALL your computer if you are the only user of the software. So for example on your laptop and desktop too without any additional fee.
geposted Mon 21 Nov 05 @ 12:09 pm
